Page 1 of 1
2001 WRX EDM don't manage to Read ECU
Posted: Thu Apr 17, 2025 7:07 pm
by Zbobz
Hello, I need some help :?
I'm trying to read my ECU on a 2001 EDM WRX for a few days (weeks maybe ?) and i don't manage to do it.
The last owner had it tuned by a friend of his but i don't know how. I only know that the tune is pretty bad !
I've tried with ECUflash, and EcuExplorer with no success.
I have a OBD2 cable that work with FreeSSM and a Tactrix clone that work with the RomRaider logger.
I thought that the problem could come from my Tactrix clone cable or from an Ecutek lock on the ECU.
That's when i discovered FastECU. I was pleased to see that it could work with an OBD cable and also remove the Ecutek lock.
Sadly, i'm still not able to read my ECU (but i can log on FastECU with both cables).
I've tested a bunch of different protocols with no success :evil:
Before you ask, yes the green plugs are connected and the car is going in test mode (tested with and without) and the jumper cable on the white connector is also in.
Here's the two best tries i've done, but usually it fails even quicker. It's seems that the software (FastECU, ECUflash...) doesn't connect quick enough to my ECU and it directly goes in Test mode (fans and fuel pump turning).
https://ibb.co/QFshNqz2
https://ibb.co/RGTR2t1Q
I've tried turning the ignition on before, at the same time, after (everything) clicking on OK to start the Read with no luck so far.
If you have any idea, cause i'm pretty much out of option on my side :cry:
Re: 2001 WRX EDM don't manage to Read ECU
Posted: Thu Apr 17, 2025 11:10 pm
by MiikaS
Please test with this version:
https://drive.google.com/file/d/1ublgG9 ... p=drivesdk
Also note that these ECUs need additional voltage pulse when accessing ECU reading/programming mode so need to use J2534 cable like Tactrix OpenPort 2 or other passthru interface.
Posted: Thu Apr 17, 2025 11:27 pm
by Zbobz
Thanks for the fast reply, I'll try that new version.
Ok so it should work with the Tactrix (if my clone cable is not bricked from using Ecuflash...).
I'll keep you updated !
Posted: Thu Apr 17, 2025 11:33 pm
by MiikaS
Zbobz wrote: Thu Apr 17, 2025 11:27 pm Thanks for the fast reply, I'll try that new version.
Yes it should work. If you can log with that tactrix, it should be ok.
Posted: Fri Apr 18, 2025 8:44 am
by Cortin
Chinese open port in 99% of cases can't provide boot pin
Posted: Fri Apr 18, 2025 12:33 pm
by Zbobz
Well, it's still not working, i still have the same thing https://ibb.co/239vCHWr
I guess it's the Tactrix Clone that doesn't work. Any way to check it ? Or any idea where i can find one that would work ? (Tactrix one is expensive but it's not even avaible)
Posted: Sat Apr 19, 2025 5:46 pm
by MiikaS
One thing you can test is to use unisia jecs 20/30 bootmode protocol. When first messagebox appears you can use multimeter to measure OBD pin 9 and 11 against GND pin, both should read ~12v.
This way you can see if the pin control work. It uses ~200ms pulse + message to jump to bootloader, so another question is does it work properly.
Posted: Mon Apr 21, 2025 11:57 am
by Zbobz
I've tested it and it seems to not be working.
I've find a used original Tactrix, hopefully it was only the clone that was causing all the issues ! I'll keep you updated when i received it.
Posted: Tue May 13, 2025 5:06 pm
by Zbobz
Finally had time to test the real Tactrix and it worked !!! :D
Thanks again for the help
Posted: Tue Jul 14, 2026 9:17 pm
by Had8pie
I seem to be having same problem with newest version of FastECU. Im mot using tactrix, but scanmatik3 it does have the j2534 passthru and multiline k-line support. Does provide voltage to OBD PIN9 on initialization, but fails with same errors so im kinda lost and not sure what the problem could be. @MiikaS is the version you shared on google drive same as beta5?
Posted: Thu Jul 16, 2026 2:18 pm
by MiikaS
Had8pie wrote: Tue Jul 14, 2026 9:17 pm I seem to be having same problem with newest version of FastECU. Im mot using tactrix, but scanmatik3 it does have the j2534 passthru and multiline k-line support. Does provide voltage to OBD PIN9 on initialization, but fails with same errors so im kinda lost and not sure what the problem could be. @MiikaS is the version you shared on google drive same as beta5?
Good question :lol: actually I'm not sure anymore. It's been bit long time since worked with it, but I think it should be as it is usually shared for testing before something is really added to release/github versions...
Can you attach/send syslog file to see the actual errors etc.?
Posted: Thu Jul 16, 2026 6:55 pm
by Had8pie
MiikaS wrote: Thu Jul 16, 2026 2:18 pm
Hey, heres the logs, one logfile with Newest exe downloaded from Git other one with the EXE that was shared on Google Drive.
