2022 WRX support?
Discussion about ECU protocols
Moderator: Global Moderator
Post Reply
dferrier
Newbie
2022 WRX support?
Post by dferrier »
I am looking for open source support for the 2022 WRX. Does FastECU support this model?
Also does it work with the Openport 2.0?
MiikaS
Administrator
Re: 2022 WRX support?
Post by MiikaS »
Supports only older models with EJ-engines and ECUs with SH7058 through Denso CAN bootloader. Newer models is on the list as soon as I have time for more development.
Openport 2.0 is supported.
dferrier
Newbie
Post by dferrier »
Excellent, since Tactrix seems to have abandoned development since 2009 or so. At least that is the date of the latest version of ECUFlash reports anyway.
I would be interested in helping you to beta test any new versions. I can pull data, whatever you need.
dferrier
Newbie
Post by dferrier »
the bar codes from the ecu label on the car
RyoSaeba
Newbie
Post by RyoSaeba »
This is the exact ecu for USDM 2022 wrx with 6MT.
Post Reply
