Denso SH7058S reflash
General discussion about FastECU
Moderator: Global Moderator
Post Reply
DarkMIKE
Newbie
Post by DarkMIKE »
Hi,
I want to ask, if I change some values in my patched ROM file (only some 10-12 values in one table) and after that I will flash it back to my ECU, how this program behaves? I mean it will flash only that changed area of offsets or it will reflash whole ROM file ? Thank you.
MiikaS
Administrator
Re: Denso SH7058S reflash
Post by MiikaS »
DarkMIKE wrote: Mon Feb 02, 2026 7:44 pm Hi,
Hi,
It should flash only the flash block that has the changed values. So small changes, usually it flashes two blocks, one with changes and second that has checksums.
DarkMIKE
Newbie
Post by DarkMIKE »
Great, thanks for info Mika, nice to read answer from you ! 8-)
Post Reply
