Installation instructions
General info and how-to
Moderator: Global Moderator
Post Reply
MiikaS
Administrator
Post by MiikaS »
For now, FastECU is build as portable package that don't need to be installed in traditional way. Software is developed with Qt and has versions for multiple platforms. As for now, there is tested versions found for Windows 10, Linux x86_64 and Linux aarch64. Windows version is zipped folder, Linux versions are AppImages. Linux x86_64 version is tested on Linux Mint 21.3 that is based on Ubuntu Jammy 22.04 and Linux aarch64 version is tested on OrangePi 5 Pro 16gb with Joshua Riek's version of Ubuntu Noble 24.04. Basicly, they should run succesfully on other distros too.
FastECU release versions can be found here.
Windows 10:
  • Download zip
  • Unzip to location you want
  • Execute FastECU.exe
Linux x86-64:
  • Download AppImage
  • Make sure AppImage is executable. Detailed instructions can be found here.
  • Execute AppImage
Linux aarch64:
  • Download AppImage
  • Execute AppImage
Linux Flatpak
  • Make sure you have flatpak and flatpak-builder installed
  • Download and extract flatpak zip
  • Go to extracted folder and run:
    • x86_64: flatpak-builder --arch=x86_64 --force-clean --user --disable-cache --install-deps-from=flathub --repo=repo --install ./fastecu ./fi.fastecu.FastECU.yml
    • aarc64: flatpak-builder --arch=aarch64 --force-clean --user --disable-cache --install-deps-from=flathub --repo=repo --install ./fastecu ./fi.fastecu.FastECU.yml
  • Wait for script to download, build and install FastECU from sources. This will also download and install all necessary dependencies.
  • Run FastECU:
    • flatpak run fi.fastecu.FastECU
mikeymeyer
Newbie
Re: Installation instructions
Post by mikeymeyer »
Are there extra steps in the installation?
This could be a connection issue, so not sure.
When opening the application it complains about no RomRaider or ECUFlash paths. Do we need to define anything here?
Fast ECU detects the Taxtrix 2.0 and connects to the ECU and lights up green.
Fast ECU 0.1.0-beta.1 - Connecting to an Impreza 2009 2.0 CAN Hitachi
You can start logging and no errors appear. However read from ECU is greyed out.
Am I choosing the wrong protocol and vehicle? Impreza 2008+ Hitachi WA1221970WWW
Or do I need to configure the ECU Flash Path and Rom Raider paths too? Each time I configure these, it switches to COM port and wont connect anymore via the OpenPort 2.0
MiikaS
Administrator
Post by MiikaS »
mikeymeyer wrote: Sat Nov 23, 2024 3:57 am Are there extra steps in the installation?
No any additional steps on installing. Sent you PM about this.
mikeymeyer
Newbie
Thanks for confirming.
I just leave the errors there each time it starts and connect any way, voila
Ravieg29
Newbie
Post by Ravieg29 »
This looks super promising! Just downloaded and will take it for a test drive on my 16 STi with Dime mod, pointed to definition folder, opened rom and tables all show up good.
Post Reply
